Marine 7000 D.U.I.-Davis Unified Ignition
Increase performance and simplify the ignition system in your boat by installing our Marine DUI Distributor! The Marine DUI (Davis Unified Ignition) is a one-piece distributor that is virtually waterproof and will withstand the severe vibrations of a marine engine. The DUI is a complete ignition system in one simple unit. No external coils or ignition boxes are necessary! Just one 12 volt hot wire hooked up to the DUI is all you need to get your marine engine running with more power and torque. Other performance ignitions require an array of messy wiring which is always suspect to the hazards of boating. Improved performance comes from our 50,000 volt coil and high dwell Dyna-Module. Plug gaps can be opened up to .055″. The increased dwell within the module makes the coil produce a longer duration spark. The combination of the two will provide the most complete burn of the fuel mixture possible. Performance is also enhanced from the super smooth advance curve tuned into the DUI. A special weight and spring assembly is hand fitted and dialed-in using a distributor machine for a precise timing curve that will match the specifications of your engine and boat. The Marine 7000 version is designed for stock to mildly modified engines that will not turn more than 7000 rpm’s. Blueprinted and precision built by polishing, lubing and setting exact tolerances as they are assembled. The Marine DUI also has flame arrestors installed which distinguishes it from our automotive DUI’s. Distributors come complete, including the brass terminal cap and rotor and stock gear. Reverse rotation gears are also available for most dual engine applications. No matter what your boat is used for, cruising, pulling skiers or all out racing, we have a DUI to fit your needs.
For more information contact Performance Distributors, 2699 Barris Dr., Memphis, TN 38132, (901)396-5782, [email protected]
www.PerformanceDistributors.com
