Towing in rain?
I have towed in the rain with just my cockpit cover a lot.
It's water proof, never had a problem. It does snap down past side glass, and over the back.
I would never use my full cover, not meant for it, I think it would flop around rubbing the gel and also catch so much air it would be like trying to pull a parachute.
That sounds like exactly what I need, I was getting ready to have one made. How do I get one?
www.dr-shrink.com is where I buy mine.
Shrink Wrap Tape is more sticky than Hull Preservation Tape. I've seen Shrink Wrap Tape pull off clearcoat before.
Shrink Wrap Tape is designed to bond shrink wrap to shrink wrap.
Hull Preservation Tape is designed to bond shrink wrap to the hull.
HPT works great for holding down the cockpit covers as well; as long as it's dry when you install it.
Been doing it this way for 10 years.
Ben, I had a new cockpit cover made for my 42 and put turn buckles at the rear of the cover where it comes down to the rub rail. I also added 3 more snaps from the rear of the cockpit towards the stern. The last thing that the guy r did was to add bungee cord into each side of the cockpit cover from the rear seat all the way to the stern with hooks on the end. You pull these bungees tight when the cover is on and hook them to the D-Rings on the transom. My cover does not come loose. Call me if you want a better expalnation.
