Stiletto with arneson's
Have a line on a set of ASD6's anyone have this setup ? It's a side bye side bravo with 650's now, would i have to get rid of notch in transom ? How do they handle, docking manners etc, not breaking bravo xr's now just thinking of cool factor, extra speed and drives strong enough to handle more power, Is this do able or should i just buy another boat? Thks Dan
Need more details on the arnesons. Are they the bravo conversion?
There will he no downside to arnesons
You might have to fill in an inch or two just where the arneson extension box is not necessarily the entire notch. Pretty easy task really.
If your not currently breaking bravos then you have a pair with the older stronger gears. Keep changing the fluid and enjoying them! If they do finally break then for sure install some arnesons before dumping money into bravos.
There's a diesel 37 with arnesons around the cape cod area I believe. So it can be done.
arneson-industries.com
Offshoreonly Advertiser
Which drives are these? If they are in line models, aka diesel drives, then for gas engines they are not the best setup.
Arneson Surface Drives www.arneson-industries.com
