Fuel cooler- do I need one? >
Old 04-13-2006, 02:02 PM
Cattitude's Avatar
Default Re: Fuel cooler- do I need one?
so is 1/2" feed enough- Aeromotive guy wants to see 5/8 but the choke point is the fitting on the tank- what's everyone else doing with bigger power?
Cattitude is offline
Old 04-13-2006, 07:23 PM
As far as the location and how to mount the pump, I installed mine on the firewall (bulkhead) about 1-1/2" lower than the hose that comes from the tank. I ran wires from a relay mounted on the engine. The pump is higher than the bilge pump so water is not a factor.
I can get a picture of it tomorrow if you like.
Kirk,
I'd like to see it. My pump was higher than what you described. I am fixing to mount the new stuff this weekend and sure would like to see what others suggest.
Tom
tomcei is offline
Old 04-13-2006, 08:28 PM
Cattitude's Avatar
Originally Posted by Pantera28-650HP
I have a 1/2" feed on my 638 HP motor, not a problem.
That's where I'm going, maybe an inch or two lower. I'm going to run it off the merc pump wires which are/were tucked out of the way on the harness. I need to drill a hole in the bulkhead for the return line, got a white plastic fitting to clean it up, will go same level as feed but just off center for easy access to the tank fittings. Fuel pressure gage comes in tomorrow- going to put the hour meter in the engine compartment rather than punch a new hole.
Old 04-14-2006, 06:17 AM
Hey Cat & 650 I guess your not able to use bolts if your below the floor on the bulk head ?
I seems as if my original system was to high. I do know it never had any issues. The boat ran and won P5 several times and never starved for fuel.
tomcei is offline
Old 04-14-2006, 08:54 AM
Cattitude's Avatar
too high is relative- I'm just anal from my rockcrawling, seen a lot of pumps killed cause of no head (bad for a marriage too).
Theoretically, once the electric pump is wet it is happy and will have a kind life. It's dry starts that are bad so you want in a valley sort of where it's always wet.
I'm using #12 or 14 1" stainless screws- the assy does not weigh that much- I'll keep an eye for loosening. You could thru bolt but you'd have to trim away the foam between the tank and the bulkhead thru the 6" access hole and it would be a pain at best. If the screws dont work I'm going well nuts which effectively thru bolts it and shock mounts it at the same time
ls1nova
3
02-04-2008 11:02 AM
Michael Garibay
6
08-08-2007 08:15 AM
Plane Silly
21
07-23-2007 09:14 PM
Cattitude
3
04-14-2006 12:55 AM
Pure Energy
2
06-18-2003 07:53 AM
Quick Reply: Fuel cooler- do I need one?
