Pantera at SCOPE Poker Run
#132
Unitops are one piece. Its like getting the tails for free...
They cost about the same as most decent manifolds plus the risers. I too have been told that the SM make more power, and I beleive the source, but they are soooo damn ugly!!!
If anyone is interested in any CMI products. I will personally handle the transaction and give you the absolute best price out there!!
Kirk
Kirk
#133
Yup all the way out! whooma!
I also put up a couple of other videos on youtube for you guys. Nothing to specatular, but better than working!
#134
Looks great. Can't wait to hear when it breaks 80.
So where is the water from the exhaust dumping???? In a pipe within the tail??? The part that you had extended just doesn't look thick enough to have water between the walls???
#135
It's a pipe inside that's the same diameter as the internal exaust pipe, then the water runs in that jacket, that's about a 1/4" larger (ID to OD) than the inner pipe. The water comes out the bottom, except for a little that squirts out the top onto the flapper to keep the flapper from frying. It's pretty trick and looks similar to the Imco setup.
#136
5 bades
I ran three different props last Sunday, conditions were great, 1 1/2' to 2' chop, 60 degree dry air. 70 gallons of gas, full cooler, I'm 220 lbs and my passenger 240 lbs.
26 5 blade 80 mph at 5700-5750 rpms stock
26 4 blade 81 mph at 6050-6100 rpms labbed somewhere in Florida
26 4 blade 83 mph at 5800-5850 rpms labbed by Brett at Bblades
My engine liked this cool air, usally I am 2 to 3 mph slower in the summer with humidity.
I am borrowing a labbed 28 4 blade from another 28 owner to see what I can do with that.
#137
83 MPH is real good speed with a true 650 HP. On the Richie's 28' I ran a stock 28' 4 blade Bravo 1 at 5300 - 5350 RPM and was right at 84 MPH on GPS with 2 people and 50 gallons of fuel.It was hotter temps and very windy conditions.I think Mike Cumming's new 28' ran 87 MPH up in Mayland with a labbed 28' at 5700 RPM but his motor is a little stronger.
If you can turn some RPM ( 5500 - 5600 ) with the 28' labbed in the right conditions you might see 85 MPH.
Regards,
JO
Regards,
JO
#140
Engine bay looks great Dude, That will haul with some dial in. I am trying to get some Ideas on target RPM's for my new power that I am building. Your drive must be pretty stout to take that kind of torque loading with a 32 wow.
