Annoying porpusing.......... >
Old 05-07-2009, 01:42 PM
Dude! Sweet!'s Avatar
Ironman had big power in his 24. I had the boat with a 330 and didn't notice any issues. Mirage 23 prop.
Dude! Sweet! is offline
Old 05-07-2009, 02:20 PM
rchevelle71's Avatar
HMMMM,
did you say Mirage 23??? Thats the same Best prop I am using, and what we used on Scotts 24(although his may have been a 25) Unfortunately, I think he has too much power for that
rchevelle71 is offline
Old 05-07-2009, 02:24 PM
That's what I think I had on there. I'm going to see the boat tomorrow so I'll check. Don't remember what Chris had on it, but I'm sure it was a bigger wheel.
Old 05-07-2009, 06:07 PM
onesickpantera's Avatar
Originally Posted by kreed
Its a 28 bravo 1. The prop is actually alittle too big I think. But I tried a 26 bravo yesterday and the " torque roll" was worse. I think I need to try a 5 blade prop to lift the hull out of the water more. Less drag, less roll ? Maybe? Im going to talk to Hydromotive and bblabes today to see what they say. Thanks for the advice.
I can tell you my boat HATED a stock Bravo prop. Rolled the boat to port and didn't have enough bow lift. Threw the boat all over the place, especially in choppy water.
My boat seems to like 3 blade props better. For all out speed I still haven't beat the standard Mirage(non-plus) and I have tried a lot of props. Last year I tried a Turbo 27 and it was close but then I blew out the rubber hub. I plan on testing it more this year.
The Rev4 was by far the best 4-blade prop I tried out of the box.
Try a Mirage or Mirage Plus 27 and see how it handles.
onesickpantera is offline
Old 05-07-2009, 07:52 PM
Hi guys-
Talked to BBlades today. Very nice guy Brett. He recommended something that no one had said yet......put a left hand rotation prop on the boat. With the 700 f/p torque driving the bow to the Left, the LH rotation prop should counteract that. He said that its pretty common in 27 to 29 ft fountains to have this problem when they put big power in them. Sounds reasonable. He also mentioned the hook in the hull, if I cant fix the problem with proping. That will be alittle down the road. So Ive borrowed a 26 LH bravo 1 to try tomorrow afternoon. Just to see if the boat rides straight at high speeds, then Ill find the right size prop. I just need to remember that when I shift in reverse, the boat will go forward!!!!!!!!!!!!!!!!!
kreed is offline
Old 05-07-2009, 07:58 PM
Hi guys-
We have already tried that, it helps, but doesnt cure it, between that and prop work though you might get rid of it.
Old 05-07-2009, 08:15 PM
your sprinkling on my parade. I really need to sleep tonight!! Im growing tired of thinking about this 24 HRS a day. Looking forward to trying this prop switch tomorrow so HOPEFULLY I can move on. Ill be happy if it goes 70 without leaning, at this point.Had NO problems with 450 HP and a 23p 3 blade prop lat year. I definatly will consider trying a 3 blade if you guys think it will help.....................
kreed is offline
Old 05-07-2009, 08:21 PM
IMO...definitely try a 3 blade.
Old 05-08-2009, 10:37 AM
JC Performance Engines
Stormrider's Avatar
550hp in my 24, liked the Mir+ best.
never tried a Mir thou.
Wasn't too fond of the B1.
Stormrider is offline
Old 05-08-2009, 10:50 AM
Sorry,
If you have access to a lefty, try it, I hope it works for you.But here we go back to the 23 3 blade again ("NO problems with 450 HP and a 23p 3 blade prop lat year"), I know you need more than 23, but I think 3 blade is going to be the ticket.
