Figured it out after many changes
Extension boxes DO work on a 24. Originally the boat would run 81-83MPH on GPS 7 1/2 inches below the bottom with a 29 mirage. Power is a massaged 525SC making 545-555HP. Boat was a handfull and always shooting for the sky in 2-3 footers. Installed a +3 box which raised the X to 4 1/2 inches. Mirage blew out at this height so didn't get a good run. Ran a Hydro P4 Labbed 28 Pitch. Boat reacted completely different. Straight as an arrow, no chine walk. No bow to the sky. Boat ran great in the ocean in 2 footers. Topped out in the calm at 86MPH @ 5900 RPM. Next, installed a 2 inch shortie, ran the same prop. Top speed was still 86MPH but at 6100RPM. Not where I wanted to run the engine. Installed a labbed 29 P5X on the shortie. Things only got better. Boat was on rails. accelerated like a raped ape. In the ocean same about 2 footers ran a consistant 78 MPH right over the top, 280 tabs just below level. In the bay, 5800RPM 90MPH and able to hold it. We did have on helmets and jackets. This boat is a light layup, my concern was being able to lift the bow at the 2 1/2 X Dim. With the high X only a touch of the trim would get the bow up. So, to those who questioned the results of a box on a 24. DO IT!!!!!!
