Hole in floor forward cabin Pantera 24
A pal and I have just started work on a very newly acquired 24. Engine out and drying out the engine bay. But we have liquid coming from the front cabin. Can some one please explain why there is water or liquid up front. There is a round hole in floor between toilet and entrance. This was full and soaking the carpets. Raised her to send liquid down to engine bay. Can we blank this hole off ? Any help suggestions would be great.
Thank you
Thank you
Thank you
Thank you
two schools of thought , Some builders count on water getting into the boat between bulkheads so the intent is to have a way for it to drain out . I now believe in sealing between all the bulkheads and not having a drain so water can swap between compartments. Sealed compartments give you more buoyancy especially in the event of a hull puncture .
I'm with Vintage Chromoly though , the tank needs to be taken out and probably replaced . Good luck and keep us updated with some pictures
Vintage Chromoly, thank you. Very comprehensive buil with pics. Thanks.
We are checking to see if tank ever replaced before cutting floor, but is it a case of getting jigsaw and cutting. Any assistance on the area needed to be cut to view tank would be really appreciated.
We have got to this point just by asking about a hole in front cabin that was soaking the carpet.
Can't post pics from my iPad. Will have to wait till I get to my pc
Thank you guys. Just to be sure the tank lies back to front under the two seats not under the rear seat running sideways. We need to cut floor of cockpit yes ?
Simon
