Pantera Floating Keychain
Well I have an ignition switch that needs to be turned to on position. Then push button makes the contact like a key would turning to start. To shut off you just flip the ignition switch off. I actually had my push button go bad last year. Luckily while on the water I was able to just take the wire line side of push button and touch it to the other side to start the boat. My boat already had this setup but shouldn't be too hard to wire like this.
