going to look at the army boat
Is the boat at a shop? I heard Scott Mander from Intense Marine moved to Quincey,Fl. If he's around , he would be the one to look at it in that area. Good Luck!
i will try to call manny on friday
not on facebook, would prefer to speak to pepe but i think he/ they have a lot on their plate right now
that yellow boat is nice, but there is another option out there for less if the army boat doesn't make the cut, but i'm hoping it does
present owners name is scott,(speed and custom marine) boat is listed in the classifieds
Hopefully your getting it for a lot less then listed . It's had some hull mods that would cause it to be expensive to turn back into a pleasure boat . Pantera used a lot of wood in their builds all the way up to the last one built so just check as best you can to make sure the stringers and transom sound dry and solid . It's been raced , bumped , jumped , and probably turned on its side several times so just look the hull over for cracks .
I use to jump in and just buy projects . Now I do the math first and show the seller the math figures .
$18,000 hull
$7500.00 even for a cheep motor
$5000.00 paint and body
$2000 upholstery
$3000 odds and ends you didn't even know you needed ...
$35000 in a 24 Pantera not the best but not the worst either !
No seller should ever mind you bringing a second set of eyes to look over a boat ..
Good luck , and keep us posted !
$18,000 hull
$2000 upholstery
http://www.offshoreonly.com/classifi...er-o64513.html
One of the cleanest 24 Pantera's ever just got listed for 25K http://www.offshoreonly.com/classifi...or-o65050.html
