Go Back  Offshoreonly.com > Owners Forum > Powerplay
To supercharge or not >
Old 06-11-2009, 03:09 PM
Originally Posted by MACTIME
Sorry I will try to post the article so all can see! If I can't I will just fax.
Great article on a 98 33 sportdeck pp with 502 making 635, 1.5 drives, spinning bravo one 28 cruise 70 and top ouot 95.
What more can a pp owners ever want?
70 mph "cruise" speed with 28's? What rpm is that?
ActiveFun is offline
Old 06-11-2009, 03:34 PM
article said 4000 rpm
I have been told that the prop was labbed.
Article was written on the Maui Jim 1998 33 pp
MACTIME is offline
Old 06-11-2009, 04:03 PM
Thats cool thanks. 4,000 rpm sounds high for a cruise speed to me. Mine is not doing 70mph at 4,000 with labbed 28's
Old 06-11-2009, 04:42 PM
what year boat do have and power?
what speeds are you seeing?
I am in the process of repowering now
MACTIME is offline
Old 06-11-2009, 04:54 PM
If you choose to go with blowers, I am selling a Littlefield 8-71 with matching carbs, fuel lines, regulator, linkage, belt, pulleys, and a Whipple intercooler that I just took off my pp.
37 hours percfect condition
MACTIME is offline
Old 06-11-2009, 10:12 PM
If you use the mercury racing website's slip calculator, that is 1% slip. Sounds pretty optimistic to me. http://www.mercuryracing.com/propell...calculator.php
I have a 2000 with HP500s, labbed 28's. My cruise at about 3500 - 3800 rpm's is like 53 to 55 mph.
Old 06-12-2009, 09:49 AM
Recommendations for a block want to stay with a short deck so I don't change the exhaust . what crank & rods & pistons should I use also whats the best compression for marine engine would like to burn reg unleaded I'm think 10:1 like I said before this is new for me street cars are a different animal
Goin Nuts is offline
Old 06-12-2009, 09:53 AM
BajaIceBreaker's Avatar
I'm confused...
If you go with a tall deck, you won't have to change the exhaust.
For example, most all aftermarket heads make HP by raising the exhaust port up to 1 inch (mine are just that) and the exhaust conforms to the change via. the rubber boots.
Am I missing something?
BajaIceBreaker is offline
Old 06-12-2009, 10:05 AM
Originally Posted by BajaIceBreaker
I'm confused...
Ok like I said this is new for me didn't know if there is any clearance issue thats why I'm here asking questions . Only want to do it once. Looking for help from the guys that been there done that
Old 06-16-2009, 07:58 AM
Originally Posted by daredevil
You are correct,,,the talldeck will not just be taller it will be wider as well.
Short deck 10:1 compression . 540 Ci ,dartheads,dart intake ,1050 dominator,,700 HP easy.
EAGLE FORDGET ROTATING ASSMBL. all ARP studs and bolts, jesel valvetrain ,,portmatch everything ,,,u be fine !!!!
6000 RPM max hydrolift and 6800 max solid !!!!
Should I use a dart block or something else if so can you gave a little info on it part# maybe not sure if the marine block is differant than street block . I have a wholesale acct to buy performance parts for street rods thanks
