Ok guys Bravo 1 question help me out like you always do
A month ago broke a gimble bell so I replace both gimble housing with Hp housing so I 2 used housing - 1 Bell if anyone needs 1 ok so after puting everything back together this week I broke the prop shaft didnot hit anything so took the drive off & took it apart needs prop shaft and carrier & prop of course and merc is real proud of the shafts . I took the upper a part to inspect and found the cap is wearing at an angle also the brass on the back of the gears is wearing the same way the clutch fork has a grove worn in it gears are in good shape so is the shaft any idea why it would be wearing like that going to put a new cap on it another thing merc it proud of
