Go Back   Offshoreonly.com > Owner's Forum > Powerquest
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 12-28-2005, 08:24 PM   #11
Charter Member #30
Scott's Avatar
PQ 38 Avenger
Re: props, spinning in or out???
Quote:
Originally Posted by jmackin
As long as your better 1/2 is w/ you you'll look cool docking.
I'm bored and feel like causing trouble.
I'd have to say your doing a fine job of it
Go check my post in LEOPA and are you going to change of watch?
I have Steps & Bubbles!
Scott is offline   Reply With Quote
Old 12-28-2005, 08:27 PM   #12
Charter Member #30
Scott's Avatar
PQ 38 Avenger
Quote:
Originally Posted by Mentalpause
So is the additional stern lift from rotating in pushing the bow down? Hopefully you can compensate with trim.
Spinning in gives you bow lift by pulling the stern down and yes the tabs will give you a nice flat ride.
Sponsored Links
Old 12-28-2005, 08:38 PM   #13
Team Kencraft
jmackin's Avatar
1998 21' kencraft
No change of watch, always seem to fall on mom's side Xmas.
Probably wont make Tadson's new years either, going to Redwings game then mbc w/ Dave and Vickie
Going to Clevland boat show on the 14th on a MBC bus trip. You going? Wanna go on a bus?
jmackin is offline   Reply With Quote
Old 12-28-2005, 08:45 PM   #14
Mentalpause's Avatar
Jassman's used worn out center console with old spilled drinks in it.
PQ380 mentioned turning them out reduces bow steer. So if turning them in increases bow lift, wouldn't it also reduce bow steer? Maybe I'm just confused. Wouldn't be the first time
John
Mentalpause is offline   Reply With Quote
Old 12-28-2005, 08:50 PM   #15
Charter Member #30
Scott's Avatar
PQ 38 Avenger
Only if I can sit in the "Special" section!
Old 12-28-2005, 08:56 PM   #16
Charter Member #30
Scott's Avatar
PQ 38 Avenger
Don't be confused
I did not go back and read his post but if that's what he said then I disagree (strongly)
Spinning in pulls the transom down creating bow lift.. Spinning out creates stern lift forcing the bow down and in the case of the 38 and the center of gravity this will cause bow steer unless you have nothing in the cabin!
See Jimmy now you got me started
Old 12-29-2005, 10:20 AM   #17
Don't be confused
Makes sense...
Rich....you may want to try this to get some bow lift in your 38.
John
Old 12-29-2005, 11:48 AM   #18
Happy to be here...
Knot 4 Me's Avatar
2004 Chaparral 260SSi
Makes sense...
I think Rich is already spinning in.
Knot 4 Me is offline   Reply With Quote
Old 12-29-2005, 04:23 PM   #19
PWRQWST's Avatar
99 38 Avenger 525sc's 600+hp
Quote:
Yep
PWRQWST is offline   Reply With Quote
Old 12-29-2005, 11:26 PM   #20
Happy to be here...
Knot 4 Me's Avatar
Quote:
Originally Posted by PWRQWST
Yep
I think the key to your getting more bow lift is to haul my fat arse in the back all the time!
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Props spinning LH or RH on single Racerngr1 Fountain 8 04-30-2008 08:02 PM
Spinning Props Inward Or Outward jeff32 General Boating Discussion 13 06-28-2006 01:16 AM
Props - spinning in or out? Chris General Boating Discussion 8 06-26-2006 11:50 AM
29 Scarab props, spinning in or out? tssteph Scarab 6 07-27-2004 04:28 PM
The props are spinning out! Sean General Boating Discussion 8 05-16-2002 05:25 PM
Search Engine Optimization by vBSEO 3.2.0
