Prop Help
Prop Help
We are going to run in the LOTO Shootout this weekend. And while it is not the last minute, it is darn close...... I need some prop advice.
Right now, I am running labbed 30 Bravo's. Max RPM on Mag HO motor's is 4700. I think the rev limiter is set to 5150. A friend has a set of 28 labbed Bravos. My question is, will it be worth the effort to change and try these to gain additional revs?
Well, it takes nothing to swap props so why not take both sets down and do a little testing before you run? I would think you would like the 28's better but no way to tell for sure until you run them. We'll be looking for you on the course. Good luck and be safe!
MIKEHTMSR24
07-22-2002 03:18 PM
