Quote:
Originally Posted by MK
If you grind them off they don't improve your speed, they just allow the hull to porpoise so you end up dropping your tab just a bit to eliminate the porpoise.
Nothing gained except the possibility of blisters due to gel work below the waterline.
The guy I talked to was an ex powerquest employee who was not a board member, but reached me through a relative who is a member of the board. For some reason I cannot find his contact info anymore which is very unusual for me, and his PM's were long deleted off the system. Do you have any idea who this would have been, and why he would have completely different info? From his voice on the phone, he sounded like an older gentleman and certainly seemed to know his stuff.
An 1/8 inch hook in the bottom of any other boat will kill top speed. I can't see how a 3/4 inch wedge would do nothing? Also, if they are doing anything to prevent porpoising, then by that fact alone, they must be in the water and exerting stern lift. It just can't work any other way.
One thing we may be forgetting: If you have experience with stock 260's with 330hp, and removal of the wedges made no difference at the 54mph top speed of that stock boat, that fact does not mean it would have no effect on the top speed of a 600hp boat.
When I first started experimenting with this boat, I ran the stock figures through hull constant calculations and came up with a hull constant of 224 which seems right for a conventional v-hull designed for comfort not top speed. As I have progressively stepped up in HP, the calculated hull constant keeps dropping (had fallen to 207 before the 2in shorty drive). This is something that should not happen unless the hull is doing something really funky as speed increases (hull constant by definition should be a constant).
My theory is that if the factory had been building 257's with HP500's they would have seen a difference with the wedges removed.
Again, I guess we'll see this spring. I'm not one to try to hide my mistakes, so I will report back.
