A few questions for his PQ newbie: As mentioned before, I have a 502 MPI supercharged with the Procharger M1. The charger lubricates directly from the engine (uses about 6 oz of oil). I also have a bravo one XR Drive with a heavy lower unit (I think a speedmaster).
What engine oil should I use? And, what drive lub? Should I use synthetic?
On my cruiser I only have oil pressure, water temp, and volt readings to worry about. My new boat has stuff I'm not familar with. So , what are normal gauge readings (both at cruise and WOT) and danger zone for the following gauges:
Boost? Exhaust temp? Water pressure? Oil temp? Fuel pressure?
Lastly --- I don't think there is a thermostat. I ran the motor off of the hose for about 10 minutes on saturday. My mechanic had a computer hooked up to get actual readings, and the water temp didn't budge. I think the computer was reading something like 60 ish. Should I have a thermostat? Will the temp. go up when running more RPM's? What should my temp readings be.
you should be okay i have a new upgraded 509 merc racing motor and i had to run mine for thru no wke zone for awhile then ran her for about 15 minutes the temp finally went up. I am from mn and was in the river the water temp is still 55 degrees so its going to take awhile . I wouldnt sweat it.
Here are some answers from a former ProCharger M1 owner and his mechanic, who is also a ProCharger distributor, and installer. Boost at an idle should be 33 to 35 lbs, at WOT (5000rpm) 55 lbs is ideal. Water pressure pressure not to exceed 30 lbs. ( I installed my water pressure gauge, just so I could look at the dash and make sure I had water runninig thru the motor). Oil temp with no thermostat, ( i didn't run one), shouldn't exceed 200 degrees. Make sure the oil is at least warm before jumping on it. We ran 25w-50, in my boat. Synthetic would be best. I would change the oil every 25 hours. If you have any other questions you can call George at Marine Performance Products, 630 240-5401. He's in northern Illinois, and will help you out. Hope this helps, Good Luck !
