| OSO Sponsor |
| OSO Sponsor |
05-29-2009, 04:12 PM
2002 38 Powerquest w/500's
A/c Unit For 38 Pq
Can anyone tell me the size of the A/C units (BTU's) that are in the 38 PQ's?
Also where are they located, are they under the V berth?
05-29-2009, 04:29 PM
S.O.B (single O/B) now
I have a 7,000 in a 38 Formula. We've installed several 10,000's.....in a 37AT that is PLENTY!!!
05-30-2009, 08:31 AM
2000 Powerquest Avenger
I have a 2000, and it's underneath the hanging locker on the left, there is a screen right below the locker and behind it is the A/C unit.
Maybe the 01's are different. I hope you don't have to remove it , it's a pain in the a@s. I had to cut fiberglass to get it out last year, and then found out I could have just replaced the controller!!!!! Oh, it's a 7,000 BTU Marine Air
Reason: forgot something
06-01-2009, 10:00 PM
2000 Powerquest 380 Avenger
Under the v birth and easy to work on. 7,000
06-02-2009, 06:33 AM
For those you have installed in the v-berth (or other areas) can you post advice/description on how to run wirining, drain, seawater pump and vents?
Thanks!
Jeff
06-09-2009, 10:32 PM
Pressurized
2001 Powerquest Avenger
I HAVE A 2001 AND ITS IN THE SAME SPOT AS BOAT HEAD, under the locker
boathead, WHWE DOES YOUR UNIT PICK UP WATER, MINE HAS A THROUGH HULL UNDER THE STEP TO THE CABIN, THE PUMP IS BEHIND THE REFRIFERATOR.
06-12-2009, 08:57 AM
Pm,
My Thru Hull Is Just In Front Of The Port Engine, And Pump Is Directly Forward Of Engine Compartment, So I Have To Open The Hatch To Open The Seacock.
06-13-2009, 07:09 AM
boathead,
So does your through hull also feed your pump out head?
I was wondering if I could pick up at the head for the AC instead of running another through hull?
Jeff
06-23-2009, 08:05 AM
no, it uses freshwater from the tank
06-23-2009, 09:45 PM
38 powerquest
My ac and head draw through the same inlet through the bottom of the hull. It works fine.
