Go Back   Offshoreonly.com > Owner's Forum > Powerquest
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-04-2010, 06:30 PM   #1
What Prop for '04 380 Avenger with 525 EFIs
Can anyone recommend the right size and pitch prop for a 2004 (twin step) 380 Avenger with 525 EFIs in it?
Klub Kleb Marine is offline   Reply With Quote
Old 01-04-2010, 06:34 PM   #2
TWIN-SPINS's Avatar
05 cig 42 tiger,w/ 525
30 bravo
TWIN-SPINS is offline   Reply With Quote
Sponsored Links
Old 01-04-2010, 09:13 PM   #3
2005 PowerQuest Poker Run Edition
I run 30" hydromotive 5 blades on my 2005 with 525's and they work great.
Powerful Addiction is offline   Reply With Quote
Old 01-04-2010, 10:31 PM   #4
PWRQWST's Avatar
99 38 Avenger 525sc's 600+hp
What ever you go with go with a 5 blade. the 4 blades suck bad on these boats. I run a 29 5 blade
PWRQWST is offline   Reply With Quote
Old 01-05-2010, 12:26 AM   #5
What is the reason why the five blades are so much better?
Old 01-05-2010, 03:56 PM   #6
Try the Mercruiser Maximus props
Check out the Mercruiser site at http://www.mercuryracing.com/propellers/maximus.php this will tell you the difference between the props. The Maximus props are very good for your application. Also the Hydromotive props work good you can check them out at http://www.hydromotive.com/ both these sites offer tech advise on the difference between the 4 and 5 blade props. The five blade are generally more money but perform better at all rpm ranges. The 29p to 30p sounds correct as the 38 with 502's 425 HP turn 28p props. There a great boat dealership in your area called The Boat Connection the owner is a world champion race boat driver and actually owns a PowerQuest boat he is very knowledgeable about props the number is 561-686-0002 ask for Howard.
boatracer81 is offline   Reply With Quote
Old 01-05-2010, 09:11 PM   #7
The 38' Powerquest with the 525's will blow out most four blades easily. I had a set of 4 - blades custom set up for the boat and even they would blow out under hard acceleration out of the hole. The five blades do not blow out and you get better performance through the entire operating range. I tested both the maximus and the hydromotive 5 blades and the hydromotive worked the best. If you call hydromotive they will set you up with the correct prop for that boat. It is a different boat with the 5 blades.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
