How to winterize Avenger, Vyper??
I back flush the A/C unit with 100 below anti freeze until it runs out the inlet on the bottom of the boat. Then I test the anti freeze to see what the temp reading is. I have been using the purple 100 below for the last two years in everything including engines.
Thanks for all the input, much appreciated!
To those that store their boats in a heated garage, to what extent do you prepare your boats for the long winter months??
When I did store warm( before the price went out of sight ) I always drained the water system and put a light dose of anti freeze through it. Drained the blocks, ran antifreeze through just to lubricate. Backed flushed the A/C just to be safe. always changed oil before storing.
sorry to jump in, but since we are on the winterize topic, why start a new thread. After you guys run anti freeze through the motors, do you drain the blocks? My first year I did, second year I didn't. Both years no damage, yet am I ok to leave just anti freeze in the blocks without draining? Thanks
