Im Gonna Need Good TABS!
Just got back from the lake (aka hurricane) and the new prop did very well. It was tough to judge top speed because there was so much chop and wind blowing me around.
I went from a 24 pitch to a 26 pitch labbed. I gained in hole-shot which surprised me and gained 2mph top end. I suspect the top end will be higher on a calmer day. I still feel like I need more trim to get the boat out of the water but end up shooting a massive rooster tail. I am still looking for a 1" spacer to get more prop in the water.
Whichever prop you end up with make sure you have Brett lab it.
And I have a 1 inch spacer on my drive. What kind of numbers are you seeing. Im running a stock 26p B1 with the spacer. with a stock 502 MPI with CMI headers. turning 5100 rpm at 67mph GPS.
Do you have Bennet Trim Tabs on the boat now? If so, you can upgrade to longer plates. http://www.bennetttrimtabs.com/
BTT are no where near as strong as K-planes, but they are well made; probably best light duty tab out there.
I don't know what kind of power you are going to have or which motor you are supercharging, but anything with forced induction should have hydrauilic steering.
what size procharger are you doing? i would think you should be starting with a 28p bravo. 32 is pretty large. best overall prop is my 28. i get great cruising with my 26 5 blade but less top end. i think i have a conservative 550hp. you may need to have whipple program your computer to make up for fuel. cant be to lean otherwise you burn it up and cant be to rich otherwise you wash out the cylinders with fuel. i still have the short tabs. i have been keeping en eye out for longer plates but surviving fine without them. i have a single ram latham assist steering. that is a must! good luck with the upgrade.
Go with steering before tabs. The hull is going to handle how the hull is going to handle, at any speed. If you need tabs to adjust how the boat is running in rough water or with a cross wind, you are not going to be at the new breakneck speeds your forced induction is taking you to. If you end up with chinewalking or a hop after forced induction, you shouldn't be trying to fix that with tabs anyhow.
IMCO makes a nice system. I'd go full to the helm if you can swing it.
Ive looked at them and have talked to a few dealers about different brands. IMCO are very nice. = very expencive. lol. Im prob gonna go with the mayfair. It seems to be the most affordable. Im not building a race boat. Just a bolt on weekend toy with some balls under the hatch.
