Our fresh water pump stopped working and need to know where to access the pump. Does anyone know where it is located or has anyone done this themselves and can give any advise?
Hello, you have the same year as me. The pump is located in the bilge on the port side between the battery and the bulkhead. The freshwater tank is on the port side under the floor of the cockpit.
I try to post a pic of each.
Regards,
Keith
PowerQuest Vyper
Regards,
Keith
PowerQuest Vyper
Regards,
Keith
PowerQuest Vyper
You can see above the long rectangle is the fresh water tank. To the stern of it is the hot water tank. The fuel tank is in the middle.
Hope this helps you. The pump is easy to check.
Regards,
Keith
PowerQuest Vyper
I will have to check it out this week. Hope its just a pump.
Thank you.
