Finally found the infamous "Ringo" cleaner
Hi AJ,
No the power 1 is biodegradable too. I did the cleaning on a rack fixture though, easier than on the trailer.
I took 3 cleaners, Simple Green, Power 1, and Ringo. I then sectioned off 3 areas on the hull bottom and applied each product. The Power 1 was a runaway. Following was Ringo and to be honest, Simple Green didn't do much of anything.
I did some research on Slimy Grimy and appears MANY people like it. Seems though it is an acid based cleaner and I don't want that. I could be wrong, so if some one knows please correct me.
OSO Moderator
Ringo has to sit on the surface for a bit. I Ringo the entire bottom, and by the time I m finished, I rinse where I started and it is like new clean.
BillR
'00 Scarab Sport 302 CC
'02 Cigarette Top Gun TS
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
BillR
'02 PQ 340
'00 PQ 280
'98 Scarab 22
'97 Baja Outlaw 20
'72 Checkmate
'65 Glastron
I'll try your method next time and report back again.
Should the hull be wet or dry when applying??
no the simple green wont do anything on the outside,,I was not sure what you were trying to clean...
I always had good luck with the Works bathtub cleaner,,buy it at the dollar store and i pour it in a spray bottle and by the time im done spraying the bottom of the boat its white again,,
Lots of folks that boat on Clinton here in central IL use the Works. It works great for the stains left by the local pond. Knot tried Power 1 once on his hull but it didn't take out the stains. But when we use Power 1 on the stains caused by a season in LOTO on my boat they disappear within a couple seconds after you spray it on the bottom. No rubbing required. I just rinse it off with a hose. Takes about 10-15 minutes to do the bottom at the end of the season. I have also used it on rust stains from well water that form under a faucet or on concrete - takes years of rust stain out in seconds.
I'm just looking for something cheap, non acid based and effective....may e they don't all fit together.
