389 avenger top speed improvement
And also, after talking with wofe, decided to keep boat. Runs too good and in great shape. Couldnt replace it for 70-80k.... ill just lab prips and maybe a few tweaks and leave it alone...
Agree, think I had one of the fastest vypers and ran 79.5 on its best day in fresh water with HOs. Don't see a 380 going the listed speed.
Also, not sure anyone in their right mind would pay in the 80s for an 03 380.
Carry on......
Carry on......
This isn't a fishing forum about that record fish that got away with no pictures.. It seems to me a forum about asking questions from ppl that have been there done that and have learned so they can share knowledge. I have ZERO reason to be dishonest. With all the research ive done prior to buying I would have agreed with u, but now I that drive it every weekend. I know what it is. If you don't belive me and can't inform the conversation with knowledge than maybe it's best you chime in on someone elses... what would I gain to ask questions if my starting point was inaccurate???!!!???
Carry on........
Carry on........
The experience I have seen with my 2000 380 is that as soon as there is a bit of chop on the lake, top speed falls off dramatically. I have been trying props and chasing a bit more top end but no matter what I put on, I end up with close to the same top end in the chop. Have yet to have a flat day to try my 30p labbed Bravo I props. Always choppy on the bay.
If I continued with stock 502 mpi, I would probably be happier with the labbed 30s. Since I have messed with the tune on my motors with slightly raised rev limiter and a bit more timing at WOT, I am actually better off with my stock 28s spinning higher rpm but can still tag 5300 limiters occasionally. Just much more acceleration, out of hole power with the 28's even though the 30's give a pretty perfect WOT rpm. I have yet to see 70 mph with my boat on GPS even though I have sheet saying factory ran it with radar at 71.8 mph. I have gained 2-3 mph across the board so far. Started at 64.5 mph when I bought it and after correcting bad injector and melted piston issues I can hit 67-68 regularly on chop. Takes a bit to get there though. Accelerates to 63-64 real quick then creeps on on top speed over a couple minutes. I get horrible prop slip numbers though.
But your hull is much better than mine given the year so that anecdotal experience may be irrelevant.
I will have a completely different setup next year with more HP and Bmax drives, and more than likely 5-blade props.
I have had mine to 82.6 GPS with 12" boxes and i run 29P 5 blades i hated the 4 blades, way to much slip. Sorry to tell you but your boat is worth maybe 70k if you are lucky. I have had mine for sale all summer and it is down to 65k with bigger motors and drives then you are running, but you do have 4 years on me.
I was also looking at the 39 Nor-tech but have decided I want a cat next.
Traded boat for a chaparral... for tubing for kids.. verg hard decision. Actually an emotional one. Love my PQ. Pissed i feel i gave it away. They gave me 75. Have it for sale for 100k.. think they will get it???? Feedback would be nice so i feel better ablut it... haa
Just keep asking, maybe you will get the answer you want.
Good move on the new boat so your family can enjoy it, if they aren't into it you wouldn't be either.
