Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-11-2005, 09:49 PM   #1
A to Z
Sean H's Avatar
Props for 30 Spectre
30 Spectre w/ 500 HP's turning 5250 w/ 1.36 and 32 bravo ones at 106.5 GPS.... (one is dinged up a little )
Five blades? Six blades?
I have heard of guys running 34's w/ 5/8" cut off the diffuser with my setup and 2" shorties....
i could handle a little more stern lift, but don't want it too loose...
Sean H is offline   Reply With Quote
Old 04-12-2005, 09:27 AM   #2
throttleup's Avatar
Throttle Up Propellers Manufacturer
Re: Props for 30 Spectre
Typically we see great results with the Hydro P5's. You will get on plane much better with these than the Bravo I props. These are the same props that we worked for Zipp Express. They had a great amount of success with the P5's. The 6B props will provide the ultimate in acceleration and would work well on a boat with excessively high drive heights and have been know to curb blade failures due to high drive heights. Keeping in mind that every time you add a blade you increase stern lift.....making the boat a little looser!
Julie
throttleup is offline   Reply With Quote
Sponsored Links
Old 04-12-2005, 10:07 AM   #3
Offshoreonly Advertiser
bbladesprops's Avatar
Smile Re: Props for 30 Spectre
Hello Sean,
We have been doing Bravo 1's for years with Jay's boats. Yes we cut the diffusers off almost all the Bravo 1's. There are certain set ups that work the best. Rotation is critical. Give Spectre or us a call and we will help you out.
920-295-4435
bbladesprops is offline   Reply With Quote
Old 04-12-2005, 12:27 PM   #4
A to Z
Sean H's Avatar
thanks guys.....
Old 04-12-2005, 11:51 PM   #5
Harper220's Avatar
2001 28 TD Daytona
I think the p5x's would work great on your set up.
Harper220 is offline   Reply With Quote
Old 04-13-2005, 07:34 AM   #6
throttleup's Avatar
The P5X's would be an excellent choice as well. They would tend to settle the stern so the boat doesn't feel as loose. They would also get the boat on plane very easily, you wouldn't have to struggle like you would with Bravo 1's. We have several sizes of the P5x's as test props.
A major advantage with the p5X compared with some other 5 blade props is that they run very well right out of the box.
Matt
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Compare 36' Spectre to 32' Spectre? Buddy OO General Boating Discussion 10 01-23-2007 07:30 PM
Bravo Props Interchangeable With Trs Props? HOTTZU98 General Q & A 3 05-13-2005 08:43 AM
polished props and satin finish props /care dougB General Q & A 0 05-06-2003 05:16 AM
30 spectre sre General Boating Discussion 7 06-16-2002 10:41 AM
Search Engine Optimization by vBSEO 3.2.0
