Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 06-03-2005, 01:53 PM   #1
SORE MEMBER
Wobble's Avatar
Kawa 1100 ZXI, SeaDoo RXP Stryker Equalizer 2800
How to test before calling prop shop.
I was wondering what is the ultimate collection of data to get before contacting a prop shop.
From what I see here.
Boat weight,
Hull type, Pad or step etc.
Motor HP and torque curve.
x dimension
drive type.
gps and rpm at wot
trim
anything else?
it would be nice to have a form we could fill, in maybe a pdf form we could print out and take with us.
thanks
Mark,
Wobble is offline   Reply With Quote
Old 06-03-2005, 02:01 PM   #2
Thumbs up Re: How to test before calling prop shop.
Call Throttle Up and Julie or Matt will tell you what they need.
Badtoon is offline   Reply With Quote
Sponsored Links
Old 06-03-2005, 02:09 PM   #3
throttleup's Avatar
Throttle Up Propellers Manufacturer
The make and pitch of the propeller used for testing.
Gear Ratio.
Testing conditions; water and weather.
Load of boat: ie; fuel, people and gear.
SEE BELOW Hope this helps
Boat LOA_________Make_____________Model____________Year_____________
Power_____________________________
Number of Engines______________
Drives_________________Gear Ratio____________ Rotation__________&____________
Baseline Prop Make/Model__________________________________
Baseline Prop Size________________X_______________________
Baseline RPM____________________________________________
Baseline MPH____________________________________________
Test Prop #1 __________________________ Size__________Diameter X_________Pitch
3500 RPM@____________________MPH
4000 RPM@____________________MPH
4500 RPM@____________________MPH
4800 RPM@____________________MPH
4900 RPM@____________________MPH
5000RPM@____________________ MPH
5100 RPM@____________________MPH
5200 RPM@____________________MPH
5300 RPM@____________________MPH
5400 RPM@____________________MPH
5500 RPM@____________________MPH
5600 RPM@____________________MPH
Comments:____________________________________________________
____________________________________________________________
_____________________________________________________________
throttleup is offline   Reply With Quote
Old 06-03-2005, 02:56 PM   #4
SORE MEMBER
Wobble's Avatar
Quote:
Gear Ratio.
Thanks Julie,
exactly what I was looking for.
Be nice if Admin could keep this near top of forum
Mark,
Old 06-03-2005, 04:52 PM   #5
throttleup's Avatar
No problem, anytime!
Julie
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Prop Shop pookie General Q & A 3 01-16-2008 11:49 AM
the prop shop awsomethunder Prop Talk 2 06-20-2007 08:00 AM
Who has the best prop shop out there!? Toffen General Boating Discussion 16 12-09-2004 09:37 AM
Prop Shop Question Damaged prop FlyFast General Q & A 1 08-06-2004 11:22 AM
Search Engine Optimization by vBSEO 3.2.0
