Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 04-16-2006, 11:03 PM   #1
98 271 fastech
Prop slipage?
If my current prop slip is @ 17% and I figure out how to get it down to 12% will I gain that 5% in top speed?
cstobe is offline   Reply With Quote
Old 04-18-2006, 01:23 PM   #2
Offshoreonly Advertiser
bbladesprops's Avatar
Smile Re: Prop slipage?
You could actually gain more than 5% in the speed category.
Likewise, if the slip goes down and so does the rpm and then drag goes up, you may gain less than 5%.
All in all you want to get your slip lowered and most likely you will gain in the speed dept.
bbladesprops is offline   Reply With Quote
Sponsored Links
Old 04-19-2006, 07:35 PM   #3
2005 Nordic Heat
Re: Prop slipage?
what is the formula for calculating prop slip???
raytart is offline   Reply With Quote
Old 04-20-2006, 01:55 AM   #4
FASTERDAMITT's Avatar
Re: Prop slipage?
here ya go. http://www.go-fast.com/Prop_Slip_Calculator.htm
FASTERDAMITT is offline   Reply With Quote
Old 04-21-2006, 11:03 PM   #5
2005 Nordic Heat
Re: Prop slipage?
thanks damitt
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Prop Blow out, What Prop? Sten Lift Problem Sick Stinger Velocity 9 02-07-2008 12:39 PM
29 scarab prop slipage shotime113 Scarab 11 09-11-2007 11:38 PM
Prop rotation (Prop Class 101) boatinbill General Boating Discussion 6 07-26-2002 10:58 AM
I need an XR prop hub kit for the 1.25"prop shaft MIKEHTMSR24 General Boating Discussion 3 07-22-2002 04:18 PM
I need an XR prop hub kit for the 1.25"prop shaft MIKEHTMSR24 General Q & A 0 07-22-2002 02:40 PM
Search Engine Optimization by vBSEO 3.2.0
