Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 01-17-2007, 07:07 PM   #11
throttleup's Avatar
Throttle Up Propellers Manufacturer
Re: help with cruise speed
Quote:
Originally Posted by marylandmark View Post
Which would be? We have emailed in the recent past about this. 26 or 28 Bravo I 4 blade is what I was thinking and you said it was a good prop but never really said if that was the best prop...
32 Concept CC with 300XS's, 8 foot beam and is about 8KLBS fully loaded...
The Bravo 1 prop will run well on your boat. It is a good prop choice. Testing with different pitch props will give you first hand results and then you can decide what runs best on your boat. Let us know if you need props to test.
throttleup is offline   Reply With Quote
Old 01-17-2007, 09:29 PM   #12
sandman
sandcraft's Avatar
1993 nordic 32 os
Quote:
Originally Posted by throttleup View Post
You will want to reduce the pitch to raise the RPM. I would stay with the 4 blade props as they seem to run well on your boat.
Testing will ultimately give you the best set up for your boat. Is the max HP 700 or is it 700@4986? I would run with as small a pitch prop as you can. The smaller pitch props will ease the stress on your drives, which are being pushed to the limit with your power. If your motors make more horsepower at rpm above 5000 then you should pick up some top end speed with a smaller pitch prop.
We have props available for testing if you need them.
That was peak hp. Peak tq is 745@4031. I agree testing is the only surefire way to do things, I just needed to know what direction to go in. I think I saw the last of the decent boating days here in NC, and probably wont start up until spring. Thanks for the help from all of you and will be in contact when the weather turns nice again.........Casey
sandcraft is offline   Reply With Quote
Sponsored Links
Old 01-18-2007, 08:10 AM   #13
throttleup's Avatar
A good rpm to shoot for will be in the low 5000 range. You are close now.
When the weather turns nice again a little less pitch will bring the rpm right where it should be. It may be worth while to try a set of stock 26 Bravo 1's to see what results you get, then go from there.
Old 01-18-2007, 10:18 AM   #14
throttleup's Avatar
Let us know when you are ready. We have a full line of Bravo I test props.
Julie
Old 01-18-2007, 10:54 AM   #15
28' Nordic Heat
Sandcraft, it appears you are experiencing a lot of slip at 3000 RPM, which is pretty normal. If this is truely a speed you want to improve on you may want to look at adding drive spacers to lower the drives down some. This will definitely help your low speed cruise but MAY cost some top end speed. Hydro P5X props will also help low speed cruise. It's all a compromise. You have to decide what is most important to you.
bobl is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
382 Cruise Speed ? J.B. Marshall Formula 8 09-02-2006 10:46 AM
whats your cruise speed? dreamer General Boating Discussion 53 07-15-2006 10:43 AM
cruise speed and rpm ratman General Boating Discussion 17 06-21-2006 11:44 AM
Labbing- Cruise speed iamfaster Prop Talk 3 09-23-2005 03:36 PM
Search Engine Optimization by vBSEO 3.2.0
