Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-02-2007, 11:46 AM   #1
masher44's Avatar
4 to 5 blade conversion
What would a size/pitch guesstimate be for converting a single 6 drive 32 Activator that runs great with a 17" x 33 4 blade to a 5 blade? Thanks Jim
masher44 is offline   Reply With Quote
Old 03-02-2007, 12:53 PM   #2
throttleup's Avatar
Throttle Up Propellers Manufacturer
Hey Masher44,
You will reduce one inch of pitch to compensate for the drag, of the additional blade.
Julie
throttleup is offline   Reply With Quote
Sponsored Links
Old 03-02-2007, 03:06 PM   #3
masher44's Avatar
I ran a 16.5 X 31 at 6700 rpms and want to get the rpms down to about 5900 and increase top speed. Boat pulls to 90 like a monster now but want to get a bit more on the top. I was thinking a 17 x 33/34 or so to get there.. will that be enough increase with the extra diameter and pitch? Also tried a 17.5 x 28 and the boat likes diameter but not sure about the 17.5 with a 33 pitch.Thanks, Jim
Old 03-02-2007, 03:15 PM   #4
throttleup's Avatar
What rpm does the motor make peak HP and TQ? Those numbers will determine the WOT rpm. Over propping a boat like your can lead to many problems.
Do you know the gear ratio?
Old 03-02-2007, 03:53 PM   #5
masher44's Avatar
It is a 32 Activator single with a wet sump 6 making about 930hp/900trq at about 6000 rpms. That boat ran 6700 with the 16.5 x 31.
1.5 on the ratio.
Old 03-02-2007, 06:03 PM   #6
throttleup's Avatar
At what RPM is the peak torque produced? Just want to make sure you stay away from that RPM. If you need to decrease 800 RPM the diameter increase with the pitch increase will do the trick. I would think that no larger than 17' diameter with that tall of a pitch. I would think 32-33P range.
Julie
Old 03-03-2007, 04:05 AM   #7
masher44's Avatar
Julie
Thanx! Just what I was thinking... I will have to find out from JC when peak torque is in mine.. I think a 17 with 32-33 is the ticket... got a cheap one for sale?
Old 03-03-2007, 03:38 PM   #8
Offshoreonly Advertiser
bbladesprops's Avatar
Wink
Going from 4 to 5 blade propellers can involve diameter adjustments. In fact, we prefere to do this to maintain speeds. I don't like to give away too many secrets on this site. People tend to copy us word for word........HEHE.
It's a 2 sided sword.
Call us anytime and we can discuss your application.
bbladesprops is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
28P Bravo 1 4 blade or 27P Mirage Plus 3 blade fandango Wanted 6 05-15-2008 08:14 PM
3 Blade vs 4 or 5 Blade Prop Comparrison Inspector Prop Talk 1 07-09-2007 08:50 AM
4 Blade switch to 5 Blade ? Your experience LFarr Prop Talk 11 08-25-2005 08:09 AM
4 blade? 5 Blade? Baja needs some cruising speed. wtpowered Prop Talk 7 07-04-2005 03:34 AM
3 blade vs. 4 blade hitch covers. Intolerant1 General Boating Discussion 20 04-08-2002 09:08 AM
Search Engine Optimization by vBSEO 3.2.0
