props needed >
props needed
props needed
Old 03-15-2007, 12:14 PM
Default props needed
Looking for used rh 21p mirage plus or 22p rh bravo1 props anyone have anything they want to get rid of?
twin242ls is offline
Old 03-21-2007, 12:55 PM
grimmy's Avatar
i have the 21p rh and lh set if you are interested in both as a set. email me if you want to talk
robert
grimmy is offline
Old 03-21-2007, 06:01 PM
Craney's Avatar
Take a look in the swap shop under used props.
Craney is offline
Old 03-23-2007, 08:38 PM
ChristianGott's Avatar
i have a 21p set of merc quicksilvers off of a 26 sutphen, 1lh,
1rh...in theory you should not have your drives spinning the same way.....an easy switch for a bravo....you can have them cheap..great shape...i've switched to 23' revolution 4's which i'd like to trade for 21's...
ChristianGott is offline
10x
Prop Talk
4
01-22-2009 09:01 PM
10x
Wanted
1
05-23-2008 04:56 PM
JJONES
Prop Talk
22
10-10-2005 07:17 PM
Scarab3DMC
04-24-2005 08:11 PM
HOUSTONPROP
Baja
0
02-27-2004 11:52 AM
Quick Reply: props needed
