Register
If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Follow us on Facebook Follow us on Twitter
Page 1 of 3 123 LastLast
Results 1 to 10 of 24
Thread: Repropping
  1. #1
    My Boats:
    2008 38 Fountain EC
    Join Date
    May 2007
    Location
    Linwood, Saginaw Bay
    Posts
    415
    Repropping
    I have a '99 35' Fountain lightning with factory-installed stellings extension boxes on 1:1.5 bravo 1s. The boat came dialed in with 28p hydromotive Q4's. I have recently repowered, 470 to 585 hp, and am looking at prop options.
    Does anyone have experience with the Bravo 1 props vs the hydromotives on this high X dimension set-up?
  2. #2
    Registered monstaaa's Avatar
    My Boats:
    fountain
    Join Date
    Feb 2005
    Location
    long island, newyork
    Posts
    2,521
    it has been my experience that bravos work better than the hydros. i would say a set of 30 lab 4 bld, 14 3/8 or 14 1/4 will rok maybe even a set of 32's.
  3. #3
    Offshoreonly Advertiser Offshoreonly Advertiser bbladesprops's Avatar
    Join Date
    Jun 2003
    Location
    Princeton, Wisconsin
    Posts
    2,812
    Smile
    Bravo 1 Labs will work better as a all aroung propeller. However, do not reduce the diameter. Leave them at the full diameter
  4. #4
    My Boats:
    fountain
    Join Date
    Feb 2005
    Location
    Posts
    2,521
    on the single step fountains we have seen back to back improvement in handling, acceleration times and turning. it tends to diminish any skitishness with these hulls due to being a single step.
    i might agree with brett if it where say a 35 or 38 twin step , especially with 525's.
  5. #5
    My Boats:
    2008 38 Fountain EC
    Join Date
    May 2007
    Location
    Posts
    415
    Have you seen any top end gained with 5b vs 4b?
  6. #6
    Join Date
    Jun 2003
    Location
    Posts
    2,812
    Smile
    With high slip % pleasure boats, a 5bl may improve top end speeds. It really becomes some what of a band aid.
    On race applications with even more agressive X's, a 5 blade may out perform the 4bl across the board.
    In general, less blades mean more speed if the over all set up is corect.
  7. #7
    My Boats:
    2008 38 Fountain EC
    Join Date
    May 2007
    Location
    Posts
    415
    Thanks Matt and Monstaaa!
    I am tending towards a 4b bravo 1, 32 for starters, that may be in need of some labbing/ thinng down if it tests a little large
    Carder
  8. #8
    My Boats:
    2008 38 Fountain EC
    Join Date
    May 2007
    Location
    Posts
    415
    Oops! I mean thanks Brett! Freudian slip?
  9. #9
    Registered throttleup's Avatar
    My Boats:
    Throttle Up Propellers Manufacturer
    Join Date
    Mar 2002
    Location
    St. Petersburg, FL
    Posts
    5,141
    Carder I will look at your emails when I get to the lab...we need to be sure the engine issue is resolved and then run thru the slip calculations. We will correlate them with dirve heigths and go from there.
    Julie
  10. #10
    My Boats:
    Join Date
    Mar 2002
    Location
    St. Petersburg, FL
    Posts
    5,141
    Quote Originally Posted by monstaaa View Post
    Uh NO.....I agree with Brett on this. A 14.25 inch diameter Bravo I propeller is not the way to go!
    Julie
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
Powered by vBulletin® Version 4.2.0
Copyright © 2013 vBulletin Solutions, Inc. All rights reserved.
Search Engine Optimization by vBSEO 3.6.1
