question re actual Bravo 1 pitch >
Old 06-20-2007, 09:16 PM
Steve Zuckerman's Avatar
Default question re actual Bravo 1 pitch
Hi Guys,
This gets knocked around from time to time and I would like to get a professional opinion from our resident prop experts.
Most of us have heard that the actual pitch of a Bravo 1 (stock) is approximately 1" to 1.5" less than stamped (ie 30" = 29" or 28.5").
A. is this true?
B. if true, is the correction 1", 1.5", or something else?
I realize all the #s can be changed with modifications (+ or - pitch and cup for instance). My reference is to a stocker.
Thanks for your input,
Steve
Steve Zuckerman is offline
Old 06-20-2007, 09:29 PM
UNSANE's Avatar
From what I understand, they are about 1" less than advertised.
UNSANE is offline
Old 06-21-2007, 07:52 AM
Pat McPherson's Avatar
I would agree.
A local prop shop that did repairs to a 26p B1 for me told me that they have measured the 26p a few times. They said that 26p B1s are slitely under 25". Then add some cup to that and they would be slightly over 25p.
Patrick
Pat McPherson is offline
Old 06-21-2007, 09:46 AM
throttleup's Avatar
Originally Posted by Steve Zuckerman
Hi Guys,
This get knocked around from time to time and I would like to get an professional opinion from our resident prop experts.
A. is this true?
Steve
Yes Steve the Bravo I props are approx 1 inch less than is stamped on the hub. The exception to this is the 34P and 36P Bravo I props they can be even more than 1 inch less. For all intensive purposes reduce one inch when calculating.
Julie
throttleup is offline
Old 06-21-2007, 01:52 PM
UNSANE's Avatar
I think it was Bblades that stated that there's a tiny bit of stern lift difference. As far as my boat is concerned, I can't tell a difference between the two, the boat acts the same, just "geared" up or down.
UNSANE is offline
Old 06-25-2007, 12:03 PM
Julie
Julie,
Thanks for the information.
Regards,
Steve
JRider
Prop Talk
8
04-03-2008 07:24 PM
bouncedcheque
Wanted
1
03-05-2008 10:50 AM
MILD THUNDER
Prop Talk
1
07-02-2007 08:39 AM
mwdill
Prop Talk
5
03-22-2007 09:38 AM
Quick Reply: question re actual Bravo 1 pitch
