01 29 fever prop ? >
01 29 fever prop ?
01 29 fever prop ?
Old 07-06-2007, 09:09 PM
Default 01 29 fever prop ?
OK just got done doing edelbrock ported heads, roller rockers, lightning headers, and programmed PCM. I had a 24 bravo 1 stock that turned 5100 all day. After the upgrades I moved up to a hydromotive 27 and can barely get 5000 @70 mph. Rev limiter is set at 5300 and was wondering what gains I would see from having rpm put into prop or just move down to a 26. Will 300 RPM make a big difference on a modded 502 mag EFI? Just curious what you guys think. Thanx!
lilredboat is offline
Old 07-07-2007, 08:48 PM
How fast were you with the B1 24 @ 5100 rpm?
Going up 3' of pitch is roughly reducing 600 rpm if you are comparing apples to apples.... but you are not, ... the B1 is a bow rasing prop and the QIV is a transom raiser.
Carder is offline
Old 07-09-2007, 06:50 AM
I never ran the 24 with the new heads etc.
Old 07-09-2007, 07:51 AM
throttleup's Avatar
Whats your gear ratio?
Julie
throttleup is offline
Old 07-09-2007, 10:31 AM
what about a 2001 29' fountain that used to be a race boat, carborated 500HP, 1.5 ratio XR, or might be an XZ, gutted cabin.. ive tried 4 props now, none were too impressive
Boomer35 is offline
Old 07-09-2007, 12:58 PM
gear ratio is 1.5. Thanx again Julie for your help on the solid hub conversion, you are the bomb! So you think you guys can get 300 rpm out of it and do you think it will help? 70 seems kinda low to me just curious.
Old 07-09-2007, 01:00 PM
If it matters I have a very high X dimension only low water pickups on drive and sucks getting on plane.
Old 07-10-2007, 09:28 PM
anyone..........anyone..........
Old 07-12-2007, 07:17 AM
my X demension is 19.5, which is high, i run a 26 pitch bravo labbed which ran way better then the 26 pitch hyrdo i tried, im thinking a 28 bravo might be the ticket, the 26 pitch bravo i have might be for sale soon if your interested
Boomer35 is offline
Old 07-12-2007, 09:17 AM
throttleup's Avatar
Thanks!
It is not wise to try to get that much RPM out of a Hydro...could lead to catastrophic failure. Is your 27P stock or labbed?
Julie
Quick Reply: 01 29 fever prop ?
