Can a single vee actually air completely out below 100 mph? >
Old 10-28-2007, 09:48 AM
Smitty,
Those are some real impressive numbers. Congrats!
Magic Medicine is offline
Old 10-28-2007, 04:19 PM
nocigarette's Avatar
i wish i could beat my boat out of the water like that......awsome numbers........It is cool to feel that jagged edge....They run real good this time if year, almost scary....
nocigarette is offline
Old 10-28-2007, 07:49 PM
Charter Member #1171
obnoxus's Avatar
Have you had your bottom done yet?
Our 272 was alot more stable after I had it blueprinted
I want to live in a world where a chicken can cross the road and not have its motives questioned.
obnoxus is offline
Old 10-28-2007, 08:18 PM
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
Boats do hit walls. I mean limits. I've seen and been there many times.
However, there are those euphoric times and situations when the stars align and you can hit the biggest numbers ever without really being scared or going for it. Remember those moments and don't "always" shoot for them again. They just happen.
[email protected]
bbladesprops is offline
Old 10-30-2007, 12:29 AM
articfriends's Avatar
Who did the bottom,what was done to it and whay kind of speeds were you running before and after. I have contemplated doing the bottom before but I'm not sure that it even runs on the hull where it has much hook when running above 80-85mph. I have considered having the transom "squared" off too,mine has a real rounded edge to it,Smitty
Here is a pic from 2 years ago doing a drive by at about 89-90 mph,there isn't much wetted hull
Attached Thumbnails Can a single vee actually air completely out below 100 mph?-copy-2-dsc03834.jpg
articfriends is offline
Old 10-30-2007, 12:43 AM
A couple of my friends keep asking me if I'm going to run the smallest pulley to break a hundred (Ihaven't ran it yet),I'm not comfortable at all with the boats ride above 95mph. I'm actually going to dial the boat in to run low to mid 90's and leave it plus I'm going to be more prudent in how the boat is loaded when I do run fast. I was running on fumes when I ran 97-98 mph,the boat needed more weight in the azz,when you would back off the gas the bow would come down and start throwing the boat around bow steering (which also leads me to believe it was really aired out pretty high) which gave me the feeling if I broke something or engine quit it would take a violent hook or roll when slowing down compared to easing out of the throttle gently. On the other hand the last time I had it out I had it loaded heavier and blew a fuel pump fuse at about 90-92 mph,the boat just settled in and drifted to a stop with no drama. I was more worried that the motor had just blown then anything else,Smitty
Old 10-31-2007, 12:02 PM
Smile
Words of wisdom............
Trim the drive in slightly and slowly before and during the retarding of the throttles when coming off a high speed run!
Makes things happier. Boat settles cleaner.
[email protected]
Old 11-05-2007, 09:47 AM
hoozeyurdaddy's Avatar
smitty, it sounds like you have reached the point of hydrodynamics met aerodynamics, even though your boat is a v-bottom, with enough speed it will start to compress air under the rear portion of the hull and leave you with nothing in the water but a prop, at that point anything can change your direction, wind, waves, ect. BE CARFULL, at that point YOU ARE NOT DRIVING, your just the throttle man.
hoozeyurdaddy is offline
Old 11-09-2007, 06:33 AM
Charter Member #927
Payton's Avatar
What you discribe sounds like how my old Mirage ran when it got up on the pad. The boat seams to raise up a little and the bow sort of searches side to side just a little. Nothing like chine walk .
Nice speeds, congrats and be carefull.
Payton is offline
Old 11-13-2007, 02:09 PM
the Flightmaster
Wild Card 09's Avatar
Wow Smitty, truly amazing numbers. I think it is great reading about what you have done with your 272. High ninetyīs must feel really special. As to the sensation you describe (and Iīm only theorising here īcos I ainīt been much past 80 in mine) I can only imagine that you are bringing the boat closer to the surface because your drive (and particularly the cavitation plate) is generating enough lift to raise the bow, whilst dropping the tabs a couple of clicks is lifting the stern. Those two are balancing out and the boat gains an extra inch of lift.
As the last few inches of the V disappears into a pad , there isnīt much left to give you directional stability.
I bet the rising sensation ties up with when you dropped the tabs. They couldnīt push the nose down because 1100 ponies were holding it high. The tail then followed.
Like I said, just plain theory, but it makes a good story.
Congrats on the baddest 272, and thanks for sharing all of your experience with us
Wild Card 09 is offline
Quick Reply: Can a single vee actually air completely out below 100 mph?
