Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 03-06-2009, 03:57 PM   #1
LostinBoston's Avatar
2004 36 Nor-Tech, For sale - make offer
Prop Efficiency curves
Does anyone have or know where to get prop efficiency curves for surface piercing props? Have any tests been done on them?
LostinBoston is offline   Reply With Quote
Old 03-06-2009, 04:16 PM   #2
A to Z
Sean H's Avatar
how are you trying to compare them? speed, rpm, slip ? probably way too many variables to have a constant curve to base anything off of.
Sean H is offline   Reply With Quote
Sponsored Links
Old 03-10-2009, 06:28 PM   #3
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
When you say efficiancy curves, what do you actually mean?
Props travel forward "x" amount of inches in 1 360 degree revolution. The propeller style and boat set up determine the amount of slip the props will have. Each boat is different so the efficiancy will vary also.
Brett
bbladesprops is offline   Reply With Quote
Old 03-14-2009, 03:48 PM   #4
Brett
Yes I am very much aware of this. By effiency I mean puting the power to the water. How much SHP is needed for calculated or scaled (based on model tests) EHP.
It would be nice to compare slip rates to increase or decrease efficiency.
Old 03-15-2009, 02:17 PM   #5
Smile
I'm sorry, I'm still not clear on what you are ultimately looking for.
Non-progressively pitched cleavers are the most efficient type of propeller as far as transfereing HP to forward travel. However, this is on a limited application. Again, variables are so overwhelming, it is impossible to have any charted efficiency hold up for everybody.
Sorry if I'm not being of assistance.
Trackbacks are Off
Refbacks are Off
Similar Threads
Thread Thread Starter Forum Replies Last Post
Bravo 2X vs 3X efficiency offshorefisher General Q & A 1 07-28-2006 06:42 PM
Drive ratios and efficiency Grog General Q & A 3 05-17-2006 05:49 PM
525 sc power curves INFUSION General Q & A 0 06-10-2005 02:59 PM
power curves Stormrider General Q & A 7 01-07-2005 05:16 PM
Propeller Efficiency Curves tomcat General Q & A 38 03-12-2002 07:30 AM
Search Engine Optimization by vBSEO 3.2.0
