Brett,
That sounds great I will be in touch after I run a 21p Mirage to get an idea of RPM.
The prop on the boat right now is a Power Tech CFS4 of unknown pitch and the boat red lines at around 45 mph loaded heavy or light.
The hole shot will embarrass a lot of boats though it's brutal and the boat equipped with a shallow blaster will plane at any trim setting with the motor down on the hyd. jack plate.
With the motor all the way up and trimmed under the boat will ventilate for a second and then it grabs and up you go in about half a boat length, I believe this is what the previous owner propped the boat to do. I however don't need the boat to do that and I would rather have more top end with a small sacrifice in hole shot.
It would be great to get about 50 mph out of the boat with a cruise around 35 mph .
John
Reason: :)
