Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 08-23-2009, 10:00 PM   #1
looking
Prop size- gear ratio
I see a big difference in props on the same boats and I know a 502 won't use a 5 to 7 inch difference over a 454. Is it gear ratio? I also understand high altitude boats use different gears. Just exactly is the scoop?? How many differant ratios are there?
Thanks Zoobed
zoobchop is offline   Reply With Quote
Old 09-01-2009, 10:03 AM   #2
hoozeyurdaddy's Avatar
2001 profile 280 cat
gear ratio's from 1.34:1 all the way to 2.20:1 are out there, the common one's are 1.34:1 to 1.65:1 depending on hp and boat.
hoozeyurdaddy is offline   Reply With Quote
Sponsored Links
Old 09-01-2009, 10:08 AM   #3
can anybody help? I need rectangle shape windows for a 30' scarab flat top 1978 . must be rectangular not slanted. does anyone u know or could you ask for me ? if some one may have a set? I need all six. thankyou . Mike . 734-377-6283.
mkmetro is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
