Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-01-2009, 10:32 PM   #1
Prop Pitch Sunesta 232 7.4L MPI
Hi, we have a 2001 Chaparral Sunesta 232 with the 7.4L MPI non-magnum engine in it and are only topping out at 4000 rpm and 55 mph. The trottle is unresponsive for the last 20 degrees or so (out of 90 degrees). It has a 19 pitch, mirage plus, 3 blade steel prop on it now. We're going down to the prop shop on Friday to try out a 17 pitch. Should we go lower than a 17? Thanks.
SToben1 is offline   Reply With Quote
Old 09-03-2009, 06:42 PM   #2
1994 Baja 236 500HP
Quote:
If the speed is GPS, that is correct. Your tach must be off. The boat should have a 21 pitch prop with a 1.5 ratio drive at about 4600 RPM.
jeffswav is offline   Reply With Quote
Sponsored Links
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
