Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 09-04-2009, 07:54 PM   #1
How many vent plugs on Mirage plus prop?
Would it hurt anything to run with only 2 of the 3 vent hole plugs in the mirage plus prop? With all the vent plugs out the prop spins out. I'd like to allow it to spin a little easier when taking off from a idle. Can this be accomplished by leaving 1 vent plug out? I don't want to put the prop out of balance. Thanks.
Ultraboy is offline   Reply With Quote
Old 09-04-2009, 08:44 PM   #2
32 pachanga
thats what the plugs are for,plugs in or out witch ever works best for you.
ext2gtx is offline   Reply With Quote
Sponsored Links
Old 09-04-2009, 09:17 PM   #3
rchevelle71's Avatar
1982 Pantera 24sport
YES,
you can mix and match.
rchevelle71 is offline   Reply With Quote
Old 09-09-2009, 01:13 PM   #4
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
Removing the vent plugs allows ambient air and exhaust gasses to escape through the holes creating a slip effect for the propeller to gain rpm on hole shot.
I usually tell people to remove all plugs to begin. Add plugs as needed to control blow out. Mixing sizes is encouraged to create the best set up.
We have all sizes in stock.
Brett
bbladesprops is offline   Reply With Quote
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
