Go Back   Offshoreonly.com > Technical > Prop Talk
OSO Sponsor
NorTech
OSO Sponsor
Advertiser
Advertiser
Old 10-31-2009, 07:08 PM   #1
Registered User
MOTION35's Avatar
04 SPECTRE 36 35MOTION SOLD 37 OUTERLIMTS SOLD 38GUN SOLD 30 MOTION
prop help
spectre 36 bravo1 36p looks labbed 5200 rpm mph 113
need 400 more rpms what can I do.
MOTION35 is offline   Reply With Quote
Old 10-31-2009, 07:55 PM   #2
Crazy Energy
Velocity Vector's Avatar
35'Ocean Express Cat
Buy my 34's they have 2 hrs. on them 800.00 shipped to your door.
The true measure of a man is how he treats someone who can do him absolutely no good.
Velocity Vector is offline   Reply With Quote
Sponsored Links
Old 11-01-2009, 07:12 AM   #3
Registered User
MOTION35's Avatar
i have 34 b
Old 11-01-2009, 07:53 AM   #4
S.O.B (single O/B) now
t500hps's Avatar
I have a set of 32 Bravo's that have been worked a bit getting them closer to 33's. They have added cup and although not labbed I had nearly an inch of the leading edges sharpened somewhat trying to get some more rpm (this left a portion of the blade at stock thickness for strength).....they still didn't work for my application so they are just sitting in the garage. For comparison, they run about 150-200 less rpm's than my labbed 32's. I'll let them go for $650.00
Russ C.
t500hps is offline   Reply With Quote
Old 11-01-2009, 08:56 AM   #5
RaggedEdge's Avatar
'06 35 Lightning Merc HP 525's aka The Black Biotch
Quote:
Russ C.
What effect did the work have on the RPM? Were they better after the work was done?
Low Tech and Proud Of It
RaggedEdge is offline   Reply With Quote
Old 11-01-2009, 09:19 AM   #6
The TORQUE from NY
HTGMotorsports's Avatar
36 Eliminator
i have 34 b
What do the 34's do on your boat ?
HTGMotorsports is offline   Reply With Quote
Old 11-01-2009, 12:23 PM   #7
Registered User
MOTION35's Avatar
34 b1 112 mph at 5600 rpm
Old 11-01-2009, 12:53 PM   #8
t500hps's Avatar
Quote:
Rpm's really didn't change......added cup reduced rpm a little, sharpening them got that little bit back. The labbed (thinned) 32's I have do get a little more rpm but they are completely diffferent props.....I ended up with some Maximus that were the better all around prop so the Bravos haven't been on the boat much.
Old 11-01-2009, 03:49 PM   #9
The TORQUE from NY
36 Eliminator
It sound to me like your motor is happier at the lower rpm...what makes you think you want rpm's higher...did you dyno? If there is more power at 5600rpm you should go faster...not slower. Your slip is very low...the 36's especially !
Old 11-01-2009, 10:33 PM   #10
Registered User
MOTION35's Avatar
props
My motors pull peak hp 5600 rpm. After 5600 the power comes down. What is my slip at know.
Trackbacks are Off
Refbacks are Off
Search Engine Optimization by vBSEO 3.2.0
