Cruiser Prop Slipping >
Old 07-30-2010, 03:16 PM
zt260's Avatar
Default Cruiser Prop Slipping
My buddy has a 1990 27' Bayliner that has lots of issues, but the main one seems to be the prop. It has a Bravo One 1.5 on it and a Mirage 19". The damn thing can barely get on plan and turns 4500rpm from 18 -28mph with the 454 300 Hp it has. Its slipping badly, but doent overrev. Shouldn't he have some other prop on there? I see old cruzers with large diamemter props that look like elephant ears. I dont know what make those larger props are.
zt260 is offline
Old 08-01-2010, 09:32 PM
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
Let's try a 17 pitch Revolution 4 or a Turbo OS1
We have them for testing.
We'll change the boat.
BAA
[email protected]
bbladesprops is offline
Old 08-02-2010, 08:58 AM
zt260's Avatar
Thanks Brett.
I went out with him this weekend and pulled the prop off. It turned out to be a laser 19". I switch to an aluminum 17 with a much larger diameter. It was actually worse. Then I found a backup prop in the boat. It was a 19" similar to a mirage, but seemed to have bigger ears with less swept back design to it. Bottom line is the boat ran good. 34mph at 4400, so I think it must be a 2.0 ratio. The previous owner gave us all bad specs.
In the off season I’ll get him to send it over to you. The prop can use some minor work and labbing to get the most out of it.
Dave
zt260 is offline
Old 08-02-2010, 09:50 AM
Smile
OK, sounds good.
Brett
[email protected]
