labbed p5x
Offshoreonly Advertiser
re,
yes we have th popular Hydros in the test program
heater63, yes we have done some work with them. I do not have a specific data base however. We would work with the current performance numbers.
[email protected]
[email protected]
We have all the P5X's.
P5Plus is so uncommon, we don't keep them in the program.
Brett
Brett
[email protected]
[email protected]
I had Hydromotive 31p5x race lab I have seen 3.5 mph increace so for in flat water there dead nuts equal very smooth but a little hard to get on plain ,I can live with that as long as 2or3 people
Just curious I am running a 29 pitch p5x to 95 mph at 6000 rpm. Boat is a Howard Sportdeck. I think I could turn a larger prop. Should I go to a 30 or 31 or 32? what do you guys suggest? I would like to still have hole shot and mid range. Do you think I could hit 100 with a larger prop? Motor is a 600 sci that has been bumped by Whipple... stage 2 ... thanks Dustin!
If the HP is pretty flat in the 5600-to 6000 area, you may gain slight speed by going up in pitch. Your slip is 13.5% which is n't bad for that hull.
Brett
Brett
[email protected]
[email protected]
