Scarab 29 single prop selection
I have just buy a 1994 Scarab 29 with a single merc 525sc. I know that this boat have an deep V hull on it. Does a 4 blade is better than a 3 blade for that boat ?
Is that 4-blade hold the hull more up of water than the 3 blade ?
If it is hold the hull up in water with a 4 blade i think the boat will run faster. Is that someone is already trying that 4 blade on this boat ?
Now i run with an 25p mirage plus 3 blade ...
What prop do you suggest... Rev 4, Bravo 1 or the Mirage plus 3 blade?
A bravo 1 4 blade is a bow raising prop i believe try and get some test props before buying guessing will get very exspensive. If you are at the Lake of the Ozarks I can hook you up with a shop that will let you test them for free
