#5 Drive props? >
#5 Drive props?
#5 Drive props?
Old 03-12-2012, 02:15 PM
Default #5 Drive props?
Any one know where or if you can find a prop for a #5 drive?
lerg948 is offline
Old 03-12-2012, 02:57 PM
CignificantOther's Avatar
Default 17 1/2 X 29 Merc 4 Blades
I have a pair of 17.5 x 29 Mercury 4 Blades available. Labbed by Throttle Up, perfect condition.
These have the interchangeable bushing inserts which will fit #5's and #6's.
CignificantOther is offline
Old 03-13-2012, 12:49 PM
Thanks man!! 29 is a little to much for me! thanks though!
lerg948 is offline
Old 03-13-2012, 03:16 PM
Registered User
What exactly are you looking for? diameter and pitch? Bob
EXCESS ENERGY is offline
Old 03-13-2012, 05:18 PM
Charter Member #394
SFOcean's Avatar
and single or pair; if single, which rotation?
I have quite a few singles in RH down to 16.75 x 25.5 (actual prop scan measurements)
SFOcean is offline
Old 03-13-2012, 07:30 PM
I have a single RH 17x29 in mint shape. 500 bucks + shipping
MILD THUNDER is offline
Old 03-14-2012, 12:50 PM
Well here s the whole deal! Im buying a 28 ft cat, dynoed at 930 at 5900, #5 drive, the guy is only 4900 with a 26, Was told i couldnt get props for a #5 , so wanted to do some checking, not sure what gear ratio and diamater. Single motor. Thanks guys, any info or suggestions is much appreciated!
lerg948 is offline
Old 03-14-2012, 01:50 PM
Isn't there an adaptor available so you can run SSM#6 shaft props on the SSM#3 and SSM#5? Pretty sure there is.
A.O. Razor is offline
Old 03-14-2012, 02:46 PM
Offshoreonly Advertiser
bbladesprops's Avatar
Smile
There is a adapter for making the 1.88" bore into 1.75" in the bushing bore type propellers.
Therefore you can run #6 props on your 5 drive. The key is whether the prop shaft has 19 or 26 splines. You need 26.
If you find a propeller within 400 rpm either way of your desired rpm goal. We most likely can get you where you need to be.
Brett
[email protected]
bbladesprops is offline
Old 04-19-2012, 12:27 PM
[QUOTE=SFOcean;3640500]and single or pair; if single, which rotation?
I have quite a few singles in RH down to 16.75 x 25.5 (actual prop scan measurements)[/QUOT You have any 28 or 29? 26 spline
lerg948 is offline
