Need help figuring out what prop to run!
28' single engine #5 setup
Has anyone ever ran a 28 ' magnum style hull with a SSM#5 drive on a singe engine making big HP ? If so where do I start with the prop? The engine is a 540 ci BBC W/twin turbos running 10-15 lbs of boost. The prop shaft centerline to bottom of keel is 1 1/2" the boat is setup with K-Plane tabs and full hydraulic steering. Boat weighs in at 4,500 lbs and the engine is in the 1,100 hp range. drive ratio is 1.34 engine RPM is 5,800-6,000 with rev limit at 6,500 I have discovered that the props for this drive can get rather pricey so I'd like to see if anyone has a good idea of where to start. I'm going to try a merc 5 blade cleaver 16% rake 18" dia 31 pitch just to see what it does. Any impute here would be great thanks
Offshoreonly Advertiser
Let us know how the test goes.
BBLADES has test propellers for your rig if you want to try some other options.
Brett
Brett
[email protected]
[email protected]
