Donzi 38ZR w/700sci, prop blowout
They are NXT drives. I walk it out the hole and maintenance around 2800 until she climbs up and bites. For some reason the starboard side begins slipping first, so it takes a little back and forth with both sides. I actually did speak with someone at BBlades and have begun to question their advice. What seemed odd was the suggestion to try to tweak the 6b props to eliminate the loose feeling. He suggested, as a test, swap the right/left prop and test drive using reverse as drive. Maybe I'm wrong but that doesn't seem right. Also, I've read that going with an outer rotation will reduce performance. Not the direction I want to go. Maybe I need to talk with Bret at BBlades.
I heard the same about the transmissions in forward they ave many clutch plates to handle the load in reverse there are far fewer plates and they cannot carry the load and will break. The rotation should be in the drives i believe you would have to swap drives not props to test in vs out. But confirm with somebody who is sure before you do anything. I am just telling what I have been told.
Offshoreonly Advertiser
a.altman.
Hello. I am back in the office for 3 days and then off to Key West for the World's.
Indeed you spoke to Brad last week in my absence. I believe Brad thought you were running Bravo XR drives which can be rotated either direction without damage. I love that ability for the simple reason of testing.
So, in your first post I understood you to say you were rotating out. Not in. I assume Brad understood this as well. That is why he would have suggested inward rotation. This rotation can aid in planning as well as add transom leverage to decrease slip % and to allow for better trim reaction. Outward rotation does indeed create more stern/transom lift and can increase slip due to wetted surface area as well as venting the propeller more. Especially with the bottom design and typical exaggerated "X" dimension of the XR hulls.
I apologize for any confusion you may have had and I would look forward to discussing your set up with you at any convenient time.
Also, Kaila called you on Friday just to let you know I was out of the office for a couple days. She seemed to think you were a little unsure of the reason for the call so I just wanted you to be sure it was just a courtesy follow up.
Thank you,
Brett
Thank you,
Brett
[email protected]
[email protected]
Brett,
Props rotate in. That was explained to Brad. He specifically stated to swap and rotate out to reduce stern lift. That's counter to anything I've read/learned. Maybe he misunderstood. I'll call you.
Yes you are right in that out will actually increase stern lift.
I don't know the contents of the conversation. Brad is on vacation this week so I can't ask him but obviously there was some miscommunication.
No problem, call when you can.
Brett
Brett
[email protected]
[email protected]
If you contact Donzi they can send you the spread sheet on the water test they did before it left the factory. Chuck Wagnor was who sent me mine but that may have changed with Everything going on at Donzi. Hopefully they still have all that data
