Need to take advantage of my raised power level >
Old 06-06-2014, 04:30 PM
Default Need to take advantage of my raised power level
Hey everyone,
I had my 383 build over the winter. Loving them. They run fantastic. They pull like crazy to around 5200-5300 and then absolutely stop pulling despite the engine making power until 5600.
I currently have Mirage 23p. What should I try next?
Captain YARRR is offline
Old 06-06-2014, 05:04 PM
try sanding off a little of the cup from the hub out maybe 2 or 3 inches and see if that gets you over the hump
pstorti is offline
Old 06-12-2014, 02:26 PM
Offshoreonly Advertiser
bbladesprops's Avatar
Sorry I missed this thread.
Theoretically going down 1-2 inches of pitch with the same style propeller will teach you a bunch and answer some questions for you. We can supply you with test propellers if you desire.
I would hesitate to removing cup anywhere on the propeller without precise adjustment knowledge.
Brett
[email protected]
bbladesprops is offline
Old 06-12-2014, 02:34 PM
Full Force's Avatar
Right..mine from the mirage plus do just that... So I need the other style insert...
Full Force is offline
Old 06-12-2014, 10:31 PM
I feel like I need more bow lift, when I cross 65+ the boat starts running extremely flat. Should I be staying in the Mirage family for that?
