Any suggestions on a better prop?
I have a 2003 crownline 202 with a 383 in it. 487hp an 492tq running thru an Alpha outdrive, with a stock Rev4 19 pitch prop. Running 5500rpm the boat tops out at 67mph on gps. I love the holeshot an mid range cruising of the 4 blade props. I like having a little open bow sleeper, that will suprise a lot of bigger boats. But I would like to see low to mid 70's.
I'm wondering if there is any difference from a Rev4 to a Bravo prop, since they are both 4 blade props. Are they that different in speed?
Any suggestions on a 4 blade prop that get me into the 70's?
Should I send my prop of to get it labbed?
Offshoreonly Advertiser
Bravo 1 props Labbed to your boat will be the faster of the 2 4 blades. The Rev4 out of the box is a excellent and tough to beat 4 blade option. The right 3 blade dialed in could the fastest however.
Call me and we can explain the differences and maybe get you a test prop to try.
Brett
Brett
[email protected]
[email protected]
