Prop slip issues on my Scarab 29 HP 500
Boats can gain alot of weight (especially if they have ever been underwater or ??) Have you weighed the boat? Do you KNOW for sure you have a 1.5 drive? Is your prop stock? So many variables but the slip is thru the roof. Im guessing your boat weighs alot more than you think but its just a guess
That is exactly my point. I have tried to different props 26 mirage plus and a four blade 25 Revolution, but with the same result. Instead of speed i just get a lot of foam behind the boat. feels like it sucks air down to the prop..
How does run? Does it get on plane easily? Does it lighten up and carry the bow OK? What about trim, tabs and drives?
Does anyone know what other single engine Scarab 29s are running for props? It may be a heavy boat but low sixties seems too slow for that engine and the slip is way too high.
Padraig
Padraig
Padraig
Padraig
I have a 95 288 sunsation
My stock 502 ran 68 with 4 blade bravo 24. I had the ecms tuned, and exhaust swapped to emi. And was blowing it out. Swapped to a 4 blade bravo 26. And ran 70. Now running a built 489 efi and running and runs 68 but back to the 24. And the 489 is making 100+ more hp. Not sure what to say about thay
How did the mirage plus perform?
How does the boat react when you trim the drive up? Does the hull loosen up as you trim up? Are you trimming up to where you start loosing speed and then dropping the trim a tad?
Please excuse the questions but I have no idea of your experience or skill.
Padraig
Padraig
A friend of mine who is an engine builder and very good with boats did the math on my boat and with a 20% prob slip in order to get 70+ mph gonna 525-550hp, could also be the out drive itself, my friend had his out drive rebuilt this year and picked up 5mph
