19 to 26 spline prop shaft adapters--shaft failures?
I have a boat with Kaama's and 19 spline long shafts. It appears that around 28pitch is about as high as 19 spline props go, which I assume is a designed limitation.
If a guy needed more that 28 pitch, it appears you need adapters, but is there a limit on what the smaller 19-spline prop shaft will take? Is it common (or has anyone experienced) a prop shaft break with the added load of a higher pitched prop/adapter?
[QUOTE=CDShack;4496940]I have a boat with Kaama's and 19 spline long shafts. It appears that around 28pitch is about as high as 19 spline props go, which I assume is a designed limitation.
MT is correct I have seen 29,30,32 in a 19 spline. I had adapters on my Formula and never had a shaft problem.
Thank ya guys!
