using larger props to lower slip #'s
Have you checked the hull for straightness, hook???, sharp trailing edges???
If you get on plane OK with the props you have but blow out at top speed - sounds like something else might be wrong.
Drive toe in or out depending on prop rotation?
Wrong style props?
Wrong style props?
Can't really use the trim at all and it does not blow out on flat water. Glass smooth water and running over a boat wake will sometimes get them to break loose. It's hard to describe but I can't tell they are right on the edge of traction. That's why I feel like I'm close and going to try the other props before the spacers. Also the props I have been trying don't have much cup out by the tip and I know that can cause some of this.
Offshoreonly Advertiser
17" of diameter should be fine for this hull. Putting the propellers 1" deeper in the water should only help, not hurt anything.
Additionally, having the propeller gone through and face lifted could help greatly.
Also, depending on what is in the cabin, your CG may be slightly forward.
Let us know if we can help with your propellers. I'd love the ability to discuss this wit you.
Brett
Brett
[email protected]
[email protected]
